Fuso FG clutch bleed
Nhem
Hello need some advice for my 2007 Fuso FG. The slave cylinder under the brake/clutch fluid does not have a way to bleed. Nothing you would find on other slave or master cylinders. So are you guys bleeding the lines from on top of trany? Or some other locations? I’m needing to do this as I think I have air in line, cannot get Fuso in gear. Any advice/ help would be appreciated. Thanks
Goldenbora
