Fuso Towing Capacity
Anyone have an idea of the towing capacity of a 2006 FG 140? I’m looking to flat tow a vehicle behind my camper.
Thanks
kerry
sharkbait73
That's funny, I literally just posted the exact same question. My bad I should have looked for existing posts.
I have the GVWR and the GCWR, I'm just not sure how they relate to each other.
The GVWR Is 14,050 lbs, the GCWR is 17,045lbs, which seems to indicate I would have a 2,995lbs towing capacity. But what happens if I don't have the truck fully loaded to 14,000lbs? For example if I only have 10,000lbs "on the truck" total with weight if truck, does that mean I then have 7,045lbs of towing? Or does towing not go up when I reduce the weight on the truck?
Mine is a 2005 FG140.
[/URL]
Sent from my Pixel 2 using Tapatalk
Bobah
