UMphreak95
So today I installed my OME caster correction bushings. I took my time, did my research and installed them the correct way so I know that isn't the issue. My caster is still way out and Im quite frustrated as to why its still in the negative. My pinion angle appears to be even worse after the bushings were installed as well. It still tracks almost perfectly straight though and I get very little vibration or growling from the driveshafts. I'm moving from Atlanta to Boulder CO in two days and I was really hoping to have my alignment as close to spec as possible before the 20 hour trip.
Specs:
97 fzj80
Ome nitro charger shocks installed 6 months ago
J springs in the rear
(not sure of the springs in the front, po never told me) 2.5 inch lift
Brand new 285/75r16 mt r's
38mm spacers
When the previous owner installed the springs he put them on opposite sides but I highly doubt it would cause my caster issue.
Alignment sheet:
Any and all input is welcomed!
Thanks guys.
Specs:
97 fzj80
38mm spacers
Alignment sheet:
Thanks guys.
