Gauge solutions for a RRC
gjackson
FRGS
So in trying to address the overheating problems in my Range Rover Classic I'm fitting an extra water temp gauge and an EGT. Does anyone have any good solutions for mounting additional gauges in/on/around the Range Rover dash?
cheers
I always thought the area just below the 'change tray' (top/center of dash) and just above the 'face' vents would be a good spot. room for at least 4.
This is the spot I will use when I get around to adding more gauges. Good visibility but not 100% sure on the wire routing.
There is a plug on the inside cowl on both the driver/pass side visible when the hood is up, this is where I run my extra wires from eng. bay to cab.
Good luck!
Pad
I will second the coin tray idea. I even saw a gauge pod made to replace that coin tray on top of middle of the dashboard.
2eleven
