Hey drivers,
I've decided to investigate a transmission repair on my Gen 1. Do ya'll know a good way to source a Gen 1 torque converter, or if the Gen 2 happens to be compatible? Thanks for any tips.
Hey drivers,
Depends on the year. Assume you have a V6? IIRC after 1990 the TC was a lockup unit - needs to be matched to a lockup transmission. KM148 aka 03-72 aka AW372 vs. AW372L (lockup) aka 03-72L (lockup). The Gen 2 3.0L V6 until '96 also used the AW372L renamed as the V4AW2 - I have one of these (labeled V4AW2) on my shop floor (from a '93) that I would certainly sell. If you have a 4 cylinder, the V4AW2 would fit with a bellhousing swap. I also have the required bellhousing sitting on a shelf.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
