'round n' back again
91 is factory, and is worn.
will be going to remove parts from a 95 SR.
as concerns the front suspension:
i am tempted to take everything;
uca lca hub (rotor, caliper)etc
half shafts
and possibly torsion bars if i can get them loose in back.
then swap that whole mess onto the 91.
here is a quote from 4x4 wire i'm curious why he used mixed control arms:
"I also picked up the 8" front from a rig in Vancouver. My front is back together. I'll have to do a writeup sometime. It's got:
- 95 SR LCAs and hubs and brakes & CV shafts
- 91 8" front diff & front driveshaft (yes, it's about 1-2 inches shorter per what I've seen on other posts)
- 97 Sport UCAs"
ill need brake master and likely booster too.
take the air compressor for giggles.
im taking the rear axle but only want the trailing arms. i like my LSD in back. it may be that discs will swap over without too much trouble onto the earlier axle.
but my drums set up properly should be ok with me.
What else should i get.
Did i make inaccurate assumptions about what will fit my earlier model?
in my research i see guys have done a mix-and-match of uca lca, and i'm going to use all from one year.
will this work?
help me out here
thanks in advance.
1991 montero lwb v6, auto, 31 tires, all original as concerns the suspension.
chrysler 3.0 and lots a cool little mods. on the rig.
half shafts
- 97 Sport UCAs"
will this work?
help me out here
thanks in advance.
