snakeyjake
Can anyone venture a guess as to why this is happening? Cylinder 1 misfire code. I can not get it to pop back on and seat properly.
PC valve was toast. Thanks.Blocked PCV coupled with long dead spark plug tube gaskets and probably equally long dead valve guide seals? Or even the plug itself not actually being threaded in right allowing blowby at the plug?
Just internet guesses
Where would I order "real mitsubishi valve tool"?Taking the upper intake off to replace the valve cover seals is easier than doing the same job on a 3.8L Mustang, people make a big deal about it but seriously it is not that hard if you just do careful methodical work.
Get the factory service manual from http://mitsubishilinks.com/ and keep a screen bigger than your phone nearby to reference, print out pages if you need to.
For the valve guide seals that's a bigger job but it's still not that terrible, I've done two of them now. As far as I can tell the easiest way to do it is you get/borrow/have an air compressor, buy this kit and also cough up the big dollars to buy the real Mitsubishi valve tool (yeah.. look it's less than the labor cost of having a shop "f" it up and you can re-sell it for as much as you paid for it so it's really just a big rental deposit) - and keep a some good lighting and a magnetic pick-up tool and some long tweezers handy... then just dive in. Do your valve guide seals, lifters, valve cover gaskets and spark plugs and wires all at the same time.
If you want to you can bundle that with doing your timing belt but there's not actually THAT much overlap between the front jobs and the top jobs.
Right now I get a tiny bit of white smoke and vapor. Barely any smoke but I'm pretty sure it's there. I'm trying to put 1000 miles or so on it and monitor oil and coolant levels. Because the radiator looks new and the service history discusses "cooling system check" I'm concerned there's a bottle of Blue Devil in it's past. I wrote a note to the previous owner to see if he would be willing to tell me anything he might be willing to share. There are also a couple of exhaust leaks, one at the first flange from intake directly above the first 02 sensor then another the first flange bracketing one of the cats. Both heat and air seem to run fine but temperatures are cool and mild. I'm still trying to figure out why this last owner donated it or abandoned it.............unless theres something much worse I haven't been able to find. So far a new turn signal stock and window regulator. Today with the pcv valve change it ran really strong.
