Gen 4 body to gen 3 chassis swap questions
voodoolord
I have been planning on swapping my body from my 78 Quadravan and was told that anything over 91 will not work. Then I saw this thread. http://www.expeditionportal.com/forum/threads/62776-4x4-Camper-Van-Project-Body-Swap He swapped a 92 onto a 90 chassis and from looking at it I think its a gen 4. So Im wondering if they were close enough with it being a 92 or is it totally compatible to go all the way into the 2000's? My 460 is carbureted with no electrics besides the duraspark ignition so I don't have to worry about obd compatibility or anything. Thanks for any tips here.
Mwilliamshs
both vans in the thread you linked are of the same, 3rd, generation. If either is a 1992 it would be in title date, not manufacture date, and it's manufacture date that makes the difference.
voodoolord
Ya I noticed that a little later after looking at the headlights. Ive found that the pre 92 has a longer frame because of the frame horn. Otherwise I think the bolts line up.
Mwilliamshs
Yes the front frame is substantially different. Crumple zones were added so the frame is longer. The frame is about the same width overall but the newer frame rails are thicker, taller, and wider. The gas tank locations are altogether different so the fuel filler locations are different as are the body shapes to accommodate them. The newer vans mount their spare tires underneath so the frames include clearance for that. Front axles are further forward (wheel wells protrude into floorboards less) but wheelbases are very similar so the rear axle is also moved forward. Engines are moved forward so interference is likely with doghouses, radiators, etc.
I'm not saying it can't be done but anybody attempting it should be prepared for a fully-involved re-framing with entirely custom mounts for most everything in contact with the frame. Driveshaft(s) will also probably need to be reworked since either axles or fenderwells will need to be relocated and the bodywork is far more expensive/time-consuming. Engine height and length will probably require some custom work on the interior as well, hopefully only in areas hidden by the doghouse. Transmissions would likely differ, as would column shifters and linkage.
If you go ahead please keep us posted. This would be very interesting to watch.
voodoolord
Well that's that. The most informative answer Ive had in weeks. Thank you very much, Theres no way I would bother with that much work and time. Looks like Ill keep looking for a pre 92. Thanks again.
Mcoleman
