Gen1 (91) Battery Drain
NorthCounty
91 LWB with a battery draw issue. Something funky is going on. Right rear lights (both brake and tail) stopped illuminating. Bulbs are good. Left rear light - tail light sometimes stays on and brake light will illuminate or function when pedal is pressed. Turn signal (right) indicator on dash steady, no flashing, right rear light displays no output from trun signal. Left turn signal operates normal. Fuses good.
Had the both brake lights staying illuminated several years ago. It was a bad or deteriorated bumper pad at the brake pedal switch. New bumper and fixed.
This one came out of no where and not sure what or where to go. Battery will be dead if sitting for more than a couple days. Read someone had issues with a hazard switch causing some lighting issues.
If anyone has suggestions or guidance, all is welcome.
Deputy Dan
