Getting camper on and off the truck.
LandRoverHyter
New to the truck camper world. Picking up our "new" to us camper next week. It's going to be siting on my flatbed dodge ram. What's everyone using to load and unload their campers? I'm not wanting to bold on corner jacks as we will never want to take the camper off away from home.
Hoping for some simple ideas without having to spend a bunch of cash.
Thanks in advance
brian90744
American Trekker
ideas on flat bed camper
You can rent jacks for loading. Also see thread=Northstar popup on flatbed.
What camper is it, and size??
just FYI
wirenut
What camper and truck?
A couple things to consider:
Can you access your spare tire with the camper on? Will your truck's jack lift the whole rig with the camper on? If you ever break down would you want to be able to live in the camper while they work on your truck?
4 corner jacks obviously work really well but if you don't want those do you own or have access to a forklift? You could build a thin frame under the camper that would allow forks to go under for removal. Do you have a garage tall enough to put the rig in where you could use an overhead hoist?
LandRoverHyter
Camper is a 2007 ATC panther
Truck is a 2004.5 dodge 3500 with a Bradford steel bed.
Spare tire is under the bed.
Truck jack will lift the truck and camper.
Not looking to take the camper off the bed while on the road.
Unfortunately no where to make a pulley system.
Kowboy
I loaded my monster Lance onto my gooseneck trailer by usin' a forklift on each side. Worked great ... but certainly helps to have a friend with two forklifts.
Prybry
It Depends...
It depends on how often you will be taking it off and on... The more often you do it, the more time and stress you will save yourself having the right jacks to do the job..
I'd spend the money on four corner bolt on jacks... the portable stands are a pain. You can always unbolt the jacks once it's on the truck.
ExpoMike
I have the corner jacks and they mount with 3 bolts each. I just bolt them on when I need to remove the camper (extremely rarely) and unbolt them when it's on the truck. Only adds about 10 minutes to the whole time.
brian90744
American Trekker
measurments
How wide is the camper and how wide is your bed?? Have you measured the camper floor to under cab-over and checked this on the truck??
the corner jack brackets stay on the camper, so you will only be removing the jacks from the brkts.
Have you throught how you are going to anchor down the camper on the truck.??
brian
LandRoverHyter
Picking the camper up next week so I will have a little better idea of how it will sit on the truck then.
As far as mounting to the truck I'm planing on using turn buckles attached to the 4 mounting rigs that came on the bed.
LandRoverHyter
The mounting jacks that mount to the camper look ok. Not real crazy about drilling into the side of the camper but I guess if
It's down right it will be ok.
LandRoverHyter
2050 miles round trip to pick it up! Very happy with it, need to do some cleaning and put down some new laminate flooring and she will be as good as new.
As for the jacks I think I'm going to go with 3 of the tripod style that I posted a picture of a few post up.
Goldenbora
