GM Van 4x4 Kits
Gvan
I have 2 complete 4x4 kits that fit any 1971-1982 1/2 ,3/4 or 1 ton Chevy or GMC vans. They would also fit 1983-1995 with some modifications (the front frame rails and steering changed in 1983). I am asking $1200 each obo.The axles and transfer case should be worth that.
The kits are from two (early 1977 110 inch wheelbase and 1979 125 inch wheelbase) Pathfinder 4x4 vans that I parted out.
They include one ton 8 bolt axles,a Dana 44 Drivers side dump font axle and GM 12 bolt full floater with a Gov lock for the rear, Ford Style (circular not racetrack) New Process 205 Transfer Cases and turbo 350 adapters, drive shafts, steering box and adapters, 4 springs, a complete frame insert with the spring mounts, an engine cross member and a bunch of little things. I have a ton of pictures (the ones below are of the frame inserts), measurements and such available as well. I have parted out a total of 4 Pathfinder vans through the years and have completed one of these kits already on one van. I had hoped to do another one but I just don't have the time right now.
The parts are located near San Jose, CA (although a third but not as complete set is in upstate NY if that is closer for you) and I can deliver for my costs.
Please let me know if sounds like something you may want...Thanks...
plh
whoa, an old one... if you take a look at Gman's profile, you will see he hasn't been on the forum since 2012
iStan814
