GMRS mobile vehicle-based units? What are my better options?
Sid Post
From the Mountain West, East, and OAS (Jay, OK) shows, I am looking to add a good mobile GMRS radio to my 70cm/2m Ham unit for friends who are not HAMs.
I like the layout and basic features of the GME brand GMRS radios, but I don't know a lot about other brands beyond junk adverts and show booths with various GMRS radios bragging about power, mainly with some questionable weather ratings, along with larger sizes and harder vehicle placements.
While 5W of power isn't much, with a good antenna, I don't think 25W or 50W would be super beneficial to me in most use cases as I only have 2.5W hand helds to loan out. Being more Line-of-Sight and broadcast power not being linear in terms of range, it also limits the value of high broadcast powers and the extra heat and physical size of the units under consideration when comparing the GME units to others.
So, what do the more experienced have to say about modern vehicle-based GMRS radio options? I am looking for an easy install, with reasonable power draw, reasonable heat generation, and a remote mount of the base unit with mic control of everything. Cellphone app integration is something I don't see myself using, but I am open to other views and reasons why I might want to link the radio to my cellphone.
The GME thread in this forum suggests that the overall feature integration and layout are good, with a buggy app that will obviously get better over time. What this lacks, though, is a good overview comparing it to other mobile GMRS options that compete against it in similar price ranges. Australian outback testing and use suggest it is likely one of the better options today.
TIA,
Sid
I have the Midland MXT-275, which appears to be similar to an equivalent GME transceiver. The Midland has a maximum output of 15 watts and can be plugged in to a cigarette lighter/power point. This unit utilizes a remote radio body connected to a speaker/mic which incorporates all the controls.
Midland MXT575 50 watts of power . You can hide the radio body and just have the microphone to control everything.
This seems like “overkill” (and a more complicated power cable installation), given that the OP stated that he did not require high transmitter power.
For a group setting I'd agree. 5 watts should do just fine. Solo and really need to reach out? I'd want every watt I can get.
I had Midland and in general they were ok. You had the range, but not the sound quality. With GME you don't necessarily have the range, but you have the sound quality. It's also made in Australia instead of China like others. If you are simply going on group rides with others that are running GMRS, then I would go with GME. If the group is using a different band(CB, HAM, Ect....) then make sure to have what they got.
TIA,
Sid
The GME are the best choice out there currently. The ones with 15W or 50W of power don't have the best audio quality or features for what you are paying for. 15W or 50W won't help you hear your friends with a handheld radio any better. 5W and a good antenna is more than fine for a trail ride. If you need to talk over a mountain, you'll probably just have to resort to NVIS...
nahuebsch
