Has anyone found a good work-around for using non goal zero panels with the Lithium Yetis? I have had a set of Overland "high efficiency" solar panels for a few years (they work great BTW). With those and a large, aka heavy as %&#@, deep cycle battery I had all the power I needed. The battery was nearing end of life so I picked up a Goal Zero Yeti 400x. I didn't know that it has a max input limitation of 22v. My panels give 33v with out using solar controller and the goal zero does not seem to recognize the solar input with the controller on the panels, which is a PWM controller, if that matters.
Can I get a different controller? I know the Yeti has one, it's just not rated to the higher volts.
TIA.
TIA.
