Goal Zero Yeti 400 Lithium Help
Jerry Ward
I'm in the process of building out a small cargo trailer into a tiny house and purchased a Goal Zero Yeti 400 Lithium with Renogy 100w panel for the electric system. I've hit a snag as I can't seem to find the MC4 to 8mm adaptor anywhere. Anyone know where I could pick one up OR have a workaround that will allow me to connect the panel to the Yeti? Thanks in advance...Jerry
The goal zero site most likely lists this part as out of stock. If you give them a call they may be able to get you one. It was listed as out of stock when I called about mine.
Get the actual spec on that 8mm plug
match against those "universal laptop adaper" kits if they won't tell you
and buy a bunch of them cheap
Get genuinedealz.com or someone with the right crimpers
to make up ones up for you in whatever lengths you need.
Or get their APP connector, much better and easier to standardize on that for all low-voltage connections.
MC4 to APP is easy to find.
Problem solved: Goal Zero does have the adaptors in stock, but will only sell them to phone-in customers only; no online, Amazon, or 3rd party retailers. Not sure why, but I have one on the way. Take care...Jerry
empireoverlandza
