Goose Gear Toyota Tacoma 2005-2023 2nd and 3rd Gen Double Cab Version 2 - Second Row Seat Delete Plate System $700 OBO
tenebs
$700
60% & 40% delete bottom plates & back panels.
Current MSRP new = $1500: 40% $725 and 60% $775
All hardware included, packed & labeled individually for each of the 4 sections so you easily know wherre the hardware is used.
Platform has always been covered by a thick foam pad so the surface is clean and like new.
This increases the backseat area storage space as well as the storage available under the 4 access panels on the bottom.
Installation instructions included but information is also available on the goosegear website.
Also including a metal molle panel & hardware that will attach to the drivers side back panel.
I also have the metal barrier that I will include so you can have 60% space behind the drivers seat for a dog and then gear behind th passenger seat. This allows you to stack gear without it falling over on to the other side.
**If you have a Factory Subwoofer this 60% Seat Delete will require removing the subwoofer. as you can see in the picture I then just had the aluminum metal box that is part of the radio system left and placed off to the side.
Goldenbora
