ntsqd
Heretic Car Camper
I did a search on the term "trans cooler" just in case I was opening up a can of worms. Only got one hit. So I thot I'd start a discussion on this & offer my thots on the common methods of adding a trans cooler. For clarity I'd like to leave discussion of the different cooler types & mounting ideas or methods to another thread.
I'll be interested to read what others have to say.
I once saw a graph in a trans re-builder trade publication that plotted trans temp with expected life span. The way the graph was laid out curve was exponential and essentially flat (nearly infinite life) to ~180*f where it started falling. At 300*f the life span was only a couple minutes.
First option: Ignore stock in-radiator cooler & replace with after market cooler.
Pros: Easy to do. Used to be the common way to do it.
Cons: May or may not be large enough to effectively replace stock, no temp regulation.
Second: Plumb in series after stock cooler.
Pro: Likely returns the coolest fluid at all times.
Cons: Fluid may never reach a temp high enough to boil out any condensation. (This is sometimes reported to be 160*f)
Third: Plumb in series ahead of the stock cooler.
Pros: Uses stock cooler to regulate fluid temp. Reduces load on stock cooler possibly adding cooling capacity to engine coolant system (little to no re-heating of 'cold' water supply to engine). Likely allows fluid to reach condensation boiling temp.
Cons: Temp cycles the fluid more vigorously, reducing it's service life.
Fourth: Plumb anywhere in series with stock cooler and use a thermostat.
Pros: Likely the best option. Regulates fluid temp and only works when needed.
Cons: More expensive, more failure modes.
My thots on each:
1) The way it used to be done, but not the best by any stretch & not worth considering on anything.
2) Better, but still not as good as it could be. Auto trans' do need some temp to operate correctly. They are designed to function at some minimum elevated temp.
3) The way I do it. I see the fluid as a service item and the trans is not.
4) The way I should do it. The t-stats are available from BAT- Mocal, Baker, Pegasus, and others. These t-stats are designed for engine oil so they by-pass a tiny bit of oil even when 'closed'. The reason is to purge air from the cooler.
No doubt I've missed something, & likely more than one.
My thots on each:
