gotta admit i need help with brake lights...Help!
i hate to admit there is anything on these machines that will slow me down, but im a bit puzzled by my brake lights-or lack thereof.
flashers running and turns all work , relays work, get power to brake switch. continuity to rear etc.
done all the stupid checks. fuses etc repalced bulbs both sides
grounds are a question but circuit works with flashers.
here is my question: on mitsubishi , does or can a faulty emergency flasher switch cause brake lights to fail. the brake lights are or seem to be wired into flasher switch.
i have no schematic. and im getting lazy right now so asking for inspiration or new ideas. i have one 1156 bulb out in front l.h. turn that would not short out the circuit?
talking outloud, if the brake switch is wired into the emergency flasher switch then what happens?
im tired cant think this through
NOTICE:
if you ever get sudden issues with your running, turn, or brake lights, and none of the "stupid tests" turn up any cause.
Suspect your hazard blinky switch.
the contacts have corroded,
or the little locks on back of the switch have broken and you have no continuity
how do i know.....
jacob_lashell
