Gowesty 16" rims. Bfg tires
Desert Magazine
Five rims and tires. Treads on Four have only a few hundred miles.
Rims are from gowesty 16 x 7.5
Tires are bf Goodrich TA km2 lt22.5 75r16. 110/107q
I can sell as a set for 1300.00
Or will separate
Tires 150 each must buy all five. 750
Rims 120 each must buy all five 600
Prefer local pickup can ship if you can arrange for shipper to pick up.
Prefer cash
pictures can be seen on the following link
www.facebook.com/azbootcamp/posts/10152388001727216?ref=notif&notif_t=like
These tires can fit a westy if it's lifted and some cutting. Lucas from gowesty wrote the following
Those wheels are probably ET38, which is too much for a 2WD up front. The tire will rub on the upper A-arm. You need to space those wheels out at least ½”—that should be enough to run a 215/70 BFG. To run the 225’s, you will have to space them out at least ¾”, 1” would be safe.
The problem then is the tires rubbing the fenders up front—you will have to do some cutting and grinding.
Westfalia, vanagon, off-road, bfg, volkswagon, syncro, gowesty
iStan814
