stioc
I'm trying to understand how the GC figures Toyota lists are measured? Are they under the diff? or other parts of the body?
For example, how can the first gen Tundra have 10.4" of ground clearance with 265/70/16? when a 3rd gen 4Runner has 9" also with the same tires? You would think the diff would be beefier in the Tundra and would hang lower than the one in the 4Runner. Also, how high the frame sits is irrelevant because given the same tire size a solid axle will more of less be the same height unless you make the diff itself smaller. So what do these number represent exactly? I don't have access to a stock 4Runner so I can't verify, however, when 8.3" was listed for the Pathfinder it was in fact 8.3" under the rear diff.
I'm just curious if anyone here has actually compared it with the specs.
