dstefan
Here's what I've got and am building: House battery in truck bed camper with National Luna DcDc portable power pack with BattleBorn 100 AH battery). Powers 50qt ARB fridge, lights, small inverter, occasional heating pad for my bad back.
Currently have the house battery/PPP in the bed with about 25' run of 6awg cable (both positive and negative) to the starter battery with 40 amp fuse (as NL specs). Using NLs supplied 6awg cable. NL only specifies returning the negative to the battery, not additional grounding. The PPP has a 63 amp circuit breaker on/off switch. It's all good, works fine in testing and with the camper vent fan temporarily running of one of the PPP 12v outputs, but have not used in the wild yet.
Plan to run the fridge line directly through the PPP box wall to the battery terminals using ARB's 10 awg wiring loom with fuse. Will run an 6" 8 awg positive and negative cable from the PPP's 50amp Anderson connector output to a Blue Sea 4321 circuit breaker switch panel with 4 protected switches (15amp each) , a 12v outlet (probably wont use this) and a USB outlet. Will have a couple very low amp LEDs lights run into the switch panel as well as the installed MaxFan. Will also add a 500 to 800 watt inverter to the PPP which will be plugged into the PPP's second 50amp Anderson output with a short 6awg cable.
I get that a frame ground isn't really necessary with the main PPP to battery connection in general (right?). Do I need to run a ground from the small Blue Sea panel (it has a negative bus) to the frame even though it returns the negative to the Battle born/PPP? Is there any reason the long run of cable to the starter battery requires a ground from the truck bed near the PPP/battery? If I run a ground from the Blue Sea panel negative bus, does that provide some help for the whole system? I do understand the issues of a good connection to the frame, if I run an additional ground in the truck bed.
For extra credit, what the hell is a ground loop?? I kept finding that in my researching and still don't get it.
Thanks!
Thanks!
