Greetings, my first post and hopefully it’s in the right spot.
A brief biography, I’m close to retirement and my wife and I want to travel in an RV, which we’ve more or less decided to be a Host TC. We feel it gives us the best blend of mobility and comfort, as we’ll be full timing for a few years.
I’ve read enough here and on other forums to understand that a big TC is not a good option for anything more than improved BLM/Nat Forest roads, and truth be told I don’t have the experience to drive anything worse than those.
However, I’ve been giving some thought to improvements for the rig and wanted to get some thoughts or see if anybody has tried this in the past.
From what I’ve read so far, one of the biggest problems driving unimproved roads with these things is the transfer of the flex from the truck bed onto the tie down points of the TC. There are other issues, but this is the one I’ve been thinking about. I’ve seen that one of the posters here suggests loosening the tie downs for smaller campers, and that gave me this idea. Would it be possible to use either an air bladder or an ‘air shock’ system to reduce the amount of flex that gets from the truck to the TC? When diving on rough roads, you would disconnect the regular tie downs, activate the air bladder system which would be in the bed of the truck to dampen the side to side motion of the TC without stressing any one hard point. You could also use some kind of smaller progressive rate spring system to minimize vertical motion of the TC, and to keep it from getting too much side to side motion if the road deteriorates.
This would require agood deal of modification to the truck, but since we’re looking at a purpose built rig anyway, that isn’t a real problem for us.
