"Some" AGM batteries can go down as low as 30% using as much as 70/80% of the batteries Capacity, My FLA Deep Cycle batteries can Go down to 30% meaning I can use 70% of their capacity, Although that might look impressive on paper The Problems start when it comes to putting the power back in to the Batteries,
If you are using Solar then you will need big panels and stay parked up for up to a couple of days at a time, If you are going to use a Battery Charger and a Generator then that can mean running the Genny/Charger for up to 16 hours +/- which is going to cost a heap in fuel not to mention the Noise it makes if there are other Campers near by,
A DC to DC Charger is another option but that will only work while you are On the road etc,
If you need your batteries to Charge quickly then AGM will Charge twice as fast as FLA, My Vehicle came factory fitted with an AGM Stop/Start Battery so the Alternator pumps out over 14.7-14.8v++ at Idle which works well, But when it comes to running my Fridge I bought a couple of Dometic PLB-40's because they can power the Fridge for a couple of days and they can be fully Charged in 2 to 4 Hours Via Solar or The Van/Campers Cigar Socket OR I can use the AC Supplied Charger via a Generator or Site Hook Up,
The PLB-40's are the fastest "Get out of Jail Free" setup money can buy, Although they are not cheap they have done away with me needing any fancy wiring and DC to DC chargers and they are 100% portable, So far they have performed faultlessly and If they are fully charged I can run the fridge from the Vehicles Cigar Socket which saves the PLB 40 Batteries for when I am parked up,
If you have enough panels on the roof then FLA batteries are hard to beat as are AGM batteries but if you are going to use a smallish G27 battery you need to have it hooked up to Solar "and" DC to DC charger 24/7,
Running 2 or 3 Big type 31 Batteries is not without it's problems, Yes they will run the fridge for up to 21 days +/- but getting the power back in and even with a 35A Charger "All" 3 batteries will not except more that about 16 to 18.5Ah So if you have 330Ah in total and you use 50% that's 165Ah, In theory at 18A is going to take 9.16 hours but in reality as the state of charge goes up the chargers output drops so that can take up to 18 hours +/- depending on the Quality/Brand of batteries used.
Sorry if all this worries you but getting a useable system that works is a minefield if you do not have the Battery Space and Panel Space, So to Avoid all that is why I went with the PLB-40's and the weight saving is awesome. works out like 150Lbs Vs about 20 to 25Lbs,
Hope that helps.
