Heavy Duty Recovery Boards
mog
Kodiak Buckaroo
I'm diggin' that reinforced added center section :giggle: on the heavy duty boards.
Head and shoulders above the old steel PSP plates (Marston Mats) my poor Kodiak has.
It wants to be adopted by TC.
llamalander
These are in a different class than plastic recovery boards because you can use them for bridging gaps/holes bigger than the tire diameter, which would fold a Maxtrax and break most other boards.
Fiberglass reinforced grating can can be used for bridging... and so can logs, but both weigh about the same, and neither reliably grow where you need them-
Victorian
100%. Most smaller vehicles would probably be fine with a plastic recovery board on shorter trips. I have friends that got stuck in snow drifts and after two attempts, the plastic boards snapped.
As soon as you are dealing with a heavy 5 ton truck you need something that not only can carry the weight but also has a minimum length to get you going. See it as "building" a road to get you out of the mud/sand/snow. Therefore the longer the traction surface, the more momentum you are getting to free yourself.
Cheers
luckyjoe
PAP is well known for soft surface use and very versatile, but bridging for a 5 ton vehicle?! Need to see some real world data and video first...
mog
Kodiak Buckaroo
Just to point out that the OP (@Victorian) is not claiming they can be used for bridging, that is another member's comment.
I have steel PSP (perforated steel plank) and while it would support a B-29 on a rolled crushed coral base layer on Iwo Jima, they would not support my Kodiak (yes, over 5 tons) without additional support in a bridging operation. YMMV
Victorian
Working on a demo video.... Stay tuned :)
Victorian
Turns out that there is bigger than expected demand for our Recovery boards! A new shipment just left Europe on the way to Canada.
We are expecting these to go fast, highly recommend acting fast if you need a set.
Our online listing: vehicle-recovery
Baartmanusa
