Help finding parts ?
onelow1ton
Hi guys I'm building a Chevy Colorado but I'm using a fzj80 front axle and suspension for my solid axle swap and I'm looking for a few things that I'm having trouble finding info on and vendors for and was hoping that some of you LC guys could help .
First thing I'm looking for is a vendor that just sells the 4 stainless extended brake lines for the front only I'm trying to avoid buying the full kit and not using the rear 3
Next would be is there another place to find a 80 series steering box FS besides ordering from cruiser parts
And next is are the front bump stops that are inside the spring on the upper spring bucket welded in or bolted or? And if there not welded in do you know where I can find some as I would like to add them to my coil buckets
Oh and also my axle came with the locker motor/actuator removed and only one bolt and from pix I see it uses one bolt and 2 studs anyone have info on where to find the studs or can I just use bolts and if so do you have specs on the size
I'm sure ill have more questions but for now these were the things I'm having trouble finding searching the web and I have been searching for a wile ,before I decided to post this so please don't flame to bad and I hope you guys are willing to help me in my search
Thanks Kenny
Sempertoy
Thanks Kenny
Kenny, join ih8mud and watch the classifieds over there. There are people parting out cruisers all the time.
Braided lines? Sleeoffroad.com will hook you up.
Pretty sure the bump stops are bolt on, but don't quote me.
Steering box, part outs over on mud. Or try ajikoverlandexchange.com for a rebuilt, quality box. Those guys do great stuff!
For vendors if you need springs, coil spacers... Yadda yadda, use Slee, camel4x4.com, cruiseroutfitters, sierraexpeditions, there are a ton of vendors.
Last but not least use this guy for OEM parts, mention mud and get a 20% discount and free shipping ;)
Sent from my iPad using Tapatalk HD
onelow1ton
Thanks , yeah I'm already on mud that's where I did my research to find that the 80 front axle was the ideal choice for my build , but I let my payed subscription run up and that place is god awful with all the adds if your not a paying member (guess its time to pay again ) I was on there last night and found a few people parting out so we will see
Thanks for the info
dhuss
