Help with a larger fuel tank
SkiFreak
Crazy Person
In my opinion, any rectangular tank is a better option than the OEM cylindrical tank that comes on the Fuso, as they take up less space and hold more fuel for a similar size.
The only real issues with changing the fuel tank are how you will mount it and finding a suitable fuel sender (if you want to use the OEM fuel gauge in the instrument cluster).
The OEM fuel sender has a non standard mounting pattern and a propriety ohm range (0=full, 150=empty and 50=half).
billiebob
Someone makes a tank which automatically pumps into the main tank.
But what are you driving ?
cameronsturgess
Thanks for heads up on fuel sender. I didn’t know it was proprietary
SkiFreak
Crazy Person
I had a 200 litre stainless fuel tank built for my truck and got a custom reed switch style sender made for it, which matches the above ohm ranges. It's a simple plug and play setup now and works perfectly with the standard instrument cluster.
My truck is a FG84, which is pretty much the same as the FG140.
pugslyyy
I have 2 50 gallon saddle tanks. The primary tank has a stock fuel sending unit, the aux tank is coupled to the primary tank.
100 gallons of fuel gives you some nice range with the Fuso.
GrantBerry
Not what you had in mind, but I have a 400L tank on the back, gravity feeds via electric 'tap'/valve into the main tank.
javajoe79
Fabricator
In regards to the odd fuel sender specs, you can get a converter so that any fuel level sender will work with your gauge.
sharkbait73
Any suggestions on replacing the stock fuel tank with a larger one ? Does the an Isuzu 50 gal work ?
Hi Cameron, what did you end up going with? I am also looking at replacing the stock cylindrical tank (I think 33gal/125L) and want to go both larger (maybe ~200-250L (~53-66gal)) and retangular, as well as I would like to see about moving it from the passenger side mount to the driver's side (along with the fuel filter and such) so i can use the passenger side for camper-side storage boxes and such.
Sophia Lopez
