here are the FILTERS REFERENCES for a CANTER 94
kookynet
off beaten tracks lovers
Hi,
We did some research -including reverse database exploration !- to allow the replacement of Oil, Air, Diesel filters, far away from your preferred dealer...
We thought it might help other fellows and save them at least three days of searching high and low :-)
for our Canter FG june 1994 - model FG 538B - engine 4D35 OAZF
Note: RHD - 24 Volts
Oil Filter
FRAM = PH8936 WIX= 516 75
NAPA= 1675 BALDWIN= B7121
DONALDSON= P 502 008 LUBER-FINER= LFP 8752
Diesel Fuel Filter
NAPA GOLD= 3397 BALDWIN= BF720
DONALDSON= P 55 02 45 FRAM= P7075
LUBER-FINER= LFF 3886 WIX= 333 97
Air Filter
FLEETGUARD AF25438 FLEETGRD
PLEASE, if you happen to find other corresponding references numbers, let us know or respond to this thread.
The main difficulty we find for filters or any parts is to have a reference number to get the search started.
Thanks. Safe trips and happy new year !
Robert and Martine :smiley_drive:
PS: currently in SF for a while, en route to Patagonia
more on air filter FLEETGUARD AF25438 FLEETGRD
Regarding the air filter FLEETGUARD AF25438 FLEETGRD
according to the source below, it is the same for
all these Mits (model ** engine **** year range)
If you happen to run into another reference number for this filter from a different manufacturer, please update this post. It will help fellow overlanders when they are abroad... Thanks.
source http://www.mannol.de/Catalogue/Filter_SCT/116655.html
MITSUBISHI: Canter *4D36 **3.6 D ***81/110 ****11/93->
MITSUBISHI: Canter *4M51 **5,2 D ****11/97->
MITSUBISHI: Canter *4D35 **4.6 D ***103/140 ****11/93->
MITSUBISHI: Canter *4D33 **4.2 D ***96/130 ****11/93->
MITSUBISHI (Japan): CANTER *4G63 **2.0 ****05/99->
MITSUBISHI (Japan): CANTER *4G63 **2.0 ****06/97->05/99
MITSUBISHI (Japan): CANTER *4G63 **2.0 ****07/03->
MITSUBISHI (Japan): CANTER *4G63 **2.0 ****02/04->
MITSUBISHI (Japan): CANTER FB *4M40 **2.8 ****05/02->
MITSUBISHI (Japan): CANTER FB *4M40 **2.8 ****05/99->
MITSUBISHI (Japan): CANTER FB *4M40 **2.8 ****11/93->05/99
MITSUBISHI (Japan): CANTER FD *4M40 **2.8 4WD ****11/93->05/99
MITSUBISHI (Japan): CANTER FD *4M40 **2.8 ****05/02->
MITSUBISHI (Japan): CANTER FD *4M40 **2.8 ****05/99->06/02
MITSUBISHI (Japan): CANTER FE *4M51 **5.2 ****05/99->06/02
MITSUBISHI (Japan): CANTER FE *4D36 **3.6 ****11/93->05/99
MITSUBISHI (Japan): CANTER FE *4D36 **3.6 ****11/97->05/99
MITSUBISHI (Japan): CANTER FE *4D33 **4.2 ****04/95->05/99
MITSUBISHI (Japan): CANTER FE *4D33 **4.2 ****05/02->
MITSUBISHI (Japan): CANTER FE *4D33 **4.2 ****05/99->06/02
MITSUBISHI (Japan): CANTER FE *4D33 **4.2 ****11/93->05/99
MITSUBISHI (Japan): CANTER FE *4D33 **4.2 ****11/97->05/99
MITSUBISHI (Japan): CANTER FE *4D35 **4.6 ****04/95->05/99
MITSUBISHI (Japan): CANTER FE *4D35 **4.6 ****11/97->05/99
MITSUBISHI (Japan): CANTER FE *4M51 **5.2 ****11/97->05/99
MITSUBISHI (Japan): CANTER FE *4D35 **4.6 ****11/93->05/99
MITSUBISHI (Japan): CANTER FE *4D35 **4.6 ****10/95->05/99
MITSUBISHI (Japan): CANTER FF *4D35 **4.6 ****11/96->05/99
MITSUBISHI (Japan): CANTER FF *4M51 **5.2 ****05/99->06/02
MITSUBISHI (Japan): CANTER FG *4D35 **4.6 4WD ****09/96->05/99
MITSUBISHI (Japan): CANTER FG *4M51 **5.2 4WD ****05/99->06/02
MITSUBISHI (Japan): CANTER FG *4D35 **4.6 4WD ****11/93->05/99
MITSUBISHI (Japan): CANTER FG *4D33 **4.2 4WD ****11/93->04/95
MITSUBISHI (Japan): CANTER FG *4D33 **4.2 4WD ****09/96->05/99
MITSUBISHI (Japan): CANTER FG *4M51 **5.2 4WD ****05/02->
MITSUBISHI (Japan): ROSA MICROBUS *4M51 **5.2 ****05/99->
MITSUBISHI (Japan): ROSA MICROBUS *4D36 **3.9 ****04/95->09/97
MITSUBISHI (Japan): ROSA MICROBUS *4D36 **3.9 ****08/97->05/00
MITSUBISHI (Japan): ROSA MICROBUS *4D33 **4.2 ****05/99->
MITSUBISHI (Japan): ROSA MICROBUS *4D35 **4.6 ****04/95->09/97
MITSUBISHI (Japan): ROSA MICROBUS *4M51 **5.0 ****08/97->05/00
MITSUBISHI (Japan): ROSA MICROBUS *4M51 **5.0 ****08/97->05/99
empireoverlandza
