Fahrvegnugen
Hey all, I’m a lifelong Jeep owner, but I’ve only ever had 2 door wranglers and one beater XJ. I wanted something a little bigger this time and a 4 door wrangler is out of the budget. I found an 03 Laredo with 92,000 with full service history since new. Trans fluid changed every 30k religiously and all other services done. I probably over paid but service history and low mileage made it worth it. Anyway, specs are 4.0 242 case trailer prep with 3.73 gears. Also not to bad. My question is since there’s not a ton of info on these, I’m thinking of going with the 4 inch iron rock critical path, leaning towards 235/80r16 on stock wheels.
My concern is both will it rub seriously and will the narrow tire have drawbacks. I know they like to dig and I drive on the beaches of the outer banks where the sand can get deep. Aired down will I be ok or should I go with wider 265s and trim? Also I’m on the east coast so rocks and mud are the name of the game. I avoid mud where possible but it’s not always possible.
Also for those of you at this height have you messed with the front driveshaft, I have CV at t case and u joint at axle. I had dual CVs and was lifted and they lasted a long time. I’ve heard conflicting information on this.
This Jeep won’t be a daily, just a foul weather car and road trip as well as a wheeler. Kind of a do it all, off road parks to road trip. Not going full crawler but it needs to get over rocks well. Any advice on good setups is appreciated.
