Hiatus Camper Shell (Mid-size, 5ft bed) 2020
Drreed5
Selling 2020 Hiatus Camper Shell (Mid-size, 5ft bed)
I bought this in 2020 from Hiatus and have really enjoyed it, however, my circumstances have changed due to work, and I need to sell as I am moving. I had several upgrades added at the time of purchase. The camper is on a short bed gen II Tacoma and is located in the Albuquerque New Mexico area.
I am asking $14,500.00 with the awning
https://www.hiatuscampers.com/
The truck is not included
Below is the build info from Hiatus
Lower aluminum skin (CHARCOAL)
Composite folding wall system
Insulated lower aluminum frame
Slide-out sleeping platform with cushions (FOREST
GREEN)
Overhead LED lighting
Front and rear slider windows with screens
Locking double back doors
Locking side access door with gas struts
Lockable draw latches
Exterior lift assist gas struts
Integrated third brake light
Upgrades
MaxxAir Fan
L-track
2 pieces were installed along the exterior of the lower
the frame of the camper (passenger side)
L-track
1 piece installed along the upper frame of the camper
(driver's side)
Arctic Tern windows
Installed in double back doors in lieu of standard windows
Yakima Tracks
Extend tracks full length of camper
Solar Port
SAE port installed on lower frame (driver's side)
Expedition Essentials
10 lbs propane holder $195
Eezi-awn Bat 270 Awning
Installed by Hiatus $1450. New
syn0s
So cool, would this also work on a 3rd gen shortbed Tacoma? What is the approximate height from the bottom of the cabover to the bed rails?
Drreed5
I think it will fit on a 3rd gen I am meeting up with a friend who has one tomorrow to measure side by side. The bedrail to the bottom of the cabover is 24 1/2"
chrisulizio20
I have a 2018 Colorado and want to check if it's compatible. Do you know the best way to do that?
I'm also interested in seeing some photos of the inside if you have them. Thanks.
sn_85
GREEN)
Upgrades
MaxxAir Fan
L-track
L-track
(driver's side)
Arctic Tern windows
Yakima Tracks
Solar Port
Installed by Hiatus $1450. New $450.00
Do you have any interior pictures? Also how the bed system is laid out and extends out.
Drreed5
Yes, it will fit the 3rd Gen but will recommend changing out one part so the camper sits flat on the rear bedrail. In talking with Hiatus it is a quick adjustment, as it is attached with screws.
syn0s
I was just reading up on the differences between 2nd and 3rd gen DCSB Tacomas and yes you are right, the 3rd gen beds are slightly deeper, which would make sense why there would be a small gap between the bottom of the barn doors and the truck bed on a 3rd gen.
I also was reading that the bed rails are in a slightly different location due to the depth/height of the truck bed too, so I would imagine new mounting hardware might need to be sourced to mount it to the bed rails.
If it's possible, I'm still very interested! I'll send you a PM!
Drreed5
camper is still available
here are a few interior pics
Seller was relocating to Wisconsin last month. He may have decided to keep it or is just dealing with the transition of the move before recommitting to the sale.
Scolpax
