Looking for some advice. I've decided to buy a winch for my truck. I'll be having a custom built bumper made. I'd like to have the winch hidden, for a couple of reasons.
1- My truck has to fit in my garage. This means the bumper needs to stay close to stock dimensions. I literally have a inch to spare front and back.
2- Aesthetically I prefer the look. This truck is my dd, I work in an office environment and keeping my vehicle "civilized" in appearance is preferred.
3- Theft, seems safer. Out of sight out of mind theory
This will be my first winch, hence the advice I am seeking....
Clutch, I cannot afford a Warn with a clutch button on the remote. I can have the bumper have a door or some form of access panel. Q- Do you use the clutch every time you use the winch, to pull the cable out? Will make a difference on the bumper design.
Cleaning, I live in a part of the world with lots of mud and salt/snow in the winter months. Being hidden, keeping the winch clean would not be easy. Big issue? Regular cleaning of the wire sufficient? Removing the bumper will be a huge ordeal..was thinking of a once a year task to clean the salt off in the spring?
Spool wheel not visible, a concern? Should I be worried that I wont be able to see the wire spooled correctly/incorrectly?
Not looking for a debate on winch selection
I am getting a Smittybilt X20 comp. Waterproof, synthetic rope, wireless controller. I figure this info might help with answers/advice on my questions above.
Thanks in advance
Ted
Thanks in advance
Ted
