Holtkamper Cocoon tent trailer
kcr
http://seattle.craigslist.org/kit/rvs/3791253949.html
SUMMER IS HERE, UNIT IS READY!
ALL ORIGINAL IMPORTED UNIT FROM THE NETHERLANDS - LICENSED IN WA
**NO FLAME RETARDANT ON CAVAS**
The Holtkamper Cocoon is incredibly easy to put up. Due to the integrated frame, the main living area of the trailer tent, can be unfolded and ready to use in minutes, including the zipped in groundsheet, and with NO pegging to do! The front canopy is permanently attached so there is no difficult zipping and unzipping to do, and with only 3 poles and guy ropes this too is incredibly easy to set up.
Spacious canopy
The large Sunrise canopy, is erected using only 3 poles. No effort at all. The canopy can be used in various ways.
Integrated groundsheet
The erection and pack away system of the Cocoon has been designed, to protect the tent fabric from the dirt on the groundsheet. If you would like to thoroughly clean the groundsheet, you are able to un-zip it from the tent.
Pack-N-Go!
With Holtkamper's Pack-N-Go system you can also access this storage area without unfolding the trailer tent. Simply unzip and lift the bed base and canvas (fitted with a gas strut for ease of lifting) thus allowing you to pack and unpack for your holiday easily. There is also a further 600 litre storage capacity under the soft top of the trailer where you can easily store items such as tables and chairs when in transit.
Control the climate
The Cocoon is equipped with a worldwide patented system for ventilation, insulation and condensation prevention: the Holtkamper Membrane Airco Tent System. Once you've used this system, you'll never want to do without it. During hot weather (over 80 degrees) you open the roof and the hot air flows out of the tent. At the same time, the sun is prevented from heating the air in the tent: the air under the outer roof, escapes straight away as soon as the sun causes the temperature to rise. In all other (normal) weather conditions, you don't need to do anything! The Membrane Airco Tent System, works automatically. There is a kind of 'climate chamber' between the two roof layers. When it rains, the climate chamber prevents condensation and in cold weather it retains the heat. In hot summer weather, the climate chamber insulates the roof from the indoor area, so that the sunshine heats up the tent less quickly. A fantastic system! And that's not all: you can even completely remove the Kyte's roof by unzipping it from the main tent. Very handy to support minor repairs or, if after many years, you decide to replace the roof.
Seeling like a Royal
Inside the Cocoon there is a double bed, with a slatted base to reduce condensation and eliminate the need for daily airing of the mattress. The mattress is made from high density foam, ensuring comfort and longevity, and the aluminum frame, fitted with gas struts, makes the bed very lightweight and easy to lift to gain access to the large, 750 litre, storage space underneath
Holtkamper Cocoon keypoints:
The Holtkamper Cocoon is incredibly easy to put up. Due to the integrated frame the main living area of the trailer tent is able to be unfolded and ready to use in minutes, including the zipped in groundsheet, and with NO pegging to do! The front canopy is permanently attached so there is no difficult zipping and unzipping to do, and with only 3 poles and guy ropes this too is incredibly easy to set up.
Unique characteristics
-Easy to set up within minutes including front awning.
-Trailer tent and front extension can be pitched without tent pegs!
-No loose front extension frames, front extension unfolds with the tent
-Suitable for all weather conditions
-Standard blinds and awnings protect against sun and rain
-Large 13" car wheels
-Alko chassis and axle with inertia brakes
-Large, comfortable latex mattress on a slatted bed
-Extremely storm resistant
-Well suited for off-road travel
-Sporty, very unique trailer design. Gravel-proof
-Compact trailer: unobstructed rear view when travelling
-Trailer can be used as a transport trailer (tent is completely removable, zips out)
-Enormous luggage area. Front extension and front extension frame occupy no luggage space while travelling!
Technical specifications
-Net weight approx. 440 lbs tow with the family sedan
-Permissible extra luggage approx. 1212 lbs
-Maximum permissible weight 1653 lbs
-Luggage space approx. 75 ft2
-Tire size 165/70 R 13", maximum speed 112 mph
-Mattress approx. 79 x 53 inches natural latex (very comfortable)
-Total surface with open front extension approx. 161 ft2
$6500.00 obo, Call or text Michael 2063539823.
