Homemade adventure trailer
Loud Al
After spending quite a bit of time looking for a ready made trailer that met my requirements I've decided to build my own.
There are several units out there that are very nice but the prices are way more than I'm willing to spend. The other nice thing about building my own is I get to expand my fabrication skills, and dust off my long dormant welding skills.
So here we go.
Plans, gotta have plans. Even if they don't survive the first steel cut :D
Wednesday my buddy Luke came over and we got a ton done
First the axle, gotta make sure it will fit between the wheels. It is 3500# 6 lug with adapters from the lug centric trailer to the hub centric Toyota wheels.
Now let's cut some steel, it is going to be all 2X3X1/8 tube, except the draw tube which will be 3X3X1/8 with a 2.5X2.5X1/8 sliding extension piece.
Gotta get a good base
This is how far we got, I have to pick up some more steel then I can finish the A for the draw bar.
Loud Al
Got the axle mounted, and parked it behind the 4Runner, I like the height. Now to paint the underside and start on the upper.
Loud Al
I had to move the axle forward, it was too much tongue weight
I got the sides installed
I got the framing for the shelf installed, this shelf is going to be bolted in so I can work on the infrastructure of the trailer
Loud Al
The water tank came in this week
Built a mount for it today
Built the top to the Water Tank cage
I picked up this saw blade from Home Depot, goes through that 1 X 1 X 1/8 like butter, much nicer than the abrasive wheel
The frame of the tailgate
skinned
Started on my extendable tow bar
Loud Al
My buddy Luke came by, so I put him to work :D
We worked on the exterior framing and fender mounts
Mocking the fenders
Fenders mounted, slowly making progress
Loud Al
I got the wiring done
I took it for a test drive, it pulls nice and straight.
A little paint, of course I will have to take some off when I put the tent platform on.
The interior is going to be all gloss white, hopefully it will help me find things.
Plumbing
I think the color combo works
Tent platform
The arms that will allow it to go up and down
bench shot
MTaco
Very cool. So do you just lift the rear up and it locks then walk around to the front and lift it and lock it in? Will be nice to see the finished product.
Loud Al
Pretty much that is the idea, we will see how well it works when I get some weight on it. I'm more worried about how fast it will drop when dropping into the travel position.
overover02
Very nice. I only wish I had the skills to attempt that. Thank you for sharing. Look forward to following the rest of the build...
Loud Al
I'm made a ton of progress, which is good because we are off to Utah on Saturday
I got the tent installed, only had to make a couple of minor modifications to the lifting system, I also had to relocate the water fill.
Here it is mostly done, just a couple of things left to do.
Fix the trailer wiring, I jury rigged the wiring to the tow rig so that needs to be fixed.
Install the canopy, I have the mounts done just need to buy some hardware.
Put another tongue jack, the trailer wiggles around a little too much right now.
Weather strip the tailgate
Phoenix
I think we need video of the tent going up and down :lurk:
Looks great! What are you using for stabilizers when the trailer is unhitched from the tow vehicle?
shazpete
