This weekend I finished my installation of a hot water system on my Toyota FJ Cruiser. One person can do this by himself but a friend (who is much more knowledgeable about cars than me) helped me and that made it a lot easier. This system can be used for showering or to make hot water to wash dishes, among other things. You could make a good argument you can go out for a weekend without a shower, but if you like to go out for longer, or if you like to hike, ride a bicycle, or swim in the ocean, a nice hot shower is a beautiful thing...
The heart of the system is a heat exchanger made by an Australian company called Glind. They have been doing these things for a long time and they make a great quality product. Fortunately for us on this side of the ocean, they have a north American distributor called Overland Shower (glindhotshower.com) who sells a complete kit including the heat exchanger and everything else you need to get hot water out of your vehicle. That makes it very easy as you don’t have to figure out what you need or look for any component. They are also extremely helpful in providing installation diagrams and all sorts of help.
First, here are all the components:
On the top you see the pressure-sensing pump. This starts to operate when you open the shower head. Below it the cylindrical piece is the Glind heat exchanger. Below that is the mixer valve. This is similar to what you use at home: rotate the faucet counterclockwise and you get more hot water; clockwise and it gets colder. Same concept except here you adjust it with a nut under that blue cap. The beauty of this is once you dial in the temperature you like you never need to touch it again. The water will always come at your preferred set temperature.
First step is to locate a suitable location for the components. Obviously every vehicle will be different. In the FJ there was a lot of empty space in the rear and front left of the engine bay.
The heat exchanger takes hot coolant from the heater block and circulates it through. Inside there’s a copper coil through which fresh water flows. As the fresh water flows through that coil, it gets heated by the surrounding hot coolant outside the coil. The two fluids never come into contact with each other, as they are two completely independent circuits. But the water in the serpentine tube inside the heat exchanger gets heated up as it flows through (thus the name “heat exchanger”, and there’s a transfer of heat from one fluid to the other).
You need to locate the coolant hose that comes out of the car’s heater core. In the FJ that is the lower of the two hoses you see on the firewall:
Where you install the heat exchanger will vary for each vehicle. You want to find a location in which it’s safe, and minimizes the length and bends of the hoses. In the FJ I mounted it to the firewall using two rivnuts.
Because this car is going off-road I wanted to strengthen the heat exchanger mount, so I added a bracket for support just in case. It probably wasn’t necessary, but just to be sure.
I put the water pump in an empty space in front of the engine bay. Again, your vehicle may be different. The pump can be mounted vertically or horizontally.
The mixer valve went close to the heat exchanger. This is a key component because without it the water can get too hot and could potentially scald you.
In terms of plumbing, here’s an overview diagram:
In essence, the way this works is:
1. Cold water is sucked in by the pump. The source can be a jerry can, a permanent on-board water tank, or even a river or lake if you carry a long hose. For the sake of simplicity I chose to use a jerry can. You can install the inlet anywhere on the vehicle. I am going straight into the pump.
Continues on next post...
