Solar is great to have, but if it is to be the primary charging source, then, in my opinion, one needs a more significant solar wattage to amp hour capacity.
Batter manufacturers recommend minimum bul charge rates, and these ueually assume you are plugging in a charger which will meet these minimum bulk rates instantly.
Solar, of course, ramps up slowly and does not meet these minimum bulk currents when the battery wants them the most.
The Alternator can be a very effective bulk charger, if cabled sufficiently and depending on what the vehicle's voltage regulator allows.
I always find my batteries respond best to a morning alternator blast, well in excess of the minimum recommended bulk charge, and then letting the solar take over for the rest of the day.
Since I cannot add more solar to my roof without incredible efforts, and I was having issues with 200 watts not being enough for 230 amp hours of battery, I deliberately lowered my overall battery capacity so that my Solar could at least come close to the 13 amp 10% bulk recommended rate from US battery.
As I rarely use more than 60 amp hours overnight, this still is less than a 50% discharge. That extra 100 amp hours of capacity I used to carry was never needed, and my group 31 battery now, seems to be holding its own against my nightly consumption and my majority solar recharge, but I love feeding it alternator amps in the morning, and the voltages it holds the next discharge cycle are always higher than if solar alone was the recharging source.
While my voltage regulator decides at some point all too soon that 13.7v is plenty, it usually allows 14.9v for long enough that the amps taper from 65 to about 25 before 13.7v comes along and asks only single digit amperages from the alternator despite the battery(s) being capable of taking much more current at higher voltages.
For the price of cabling and a Blue seas ACR, the alternator bulk charging your battery bank even for a short duration, could well extend the life of your battery bank and possible more than make up for their additional initial cost.
Battery charging is all about taking advantage of all available charging sources to keep the batteries at the highest state of charge possible. I personally would not remove one of the biggest bulk chargers available. Thirsty batteries should be allowed to be quenched, in my opinion. Low and slow might be fine and dandy when one has a week to recharge, but when the next discharge cycle begins before sundown that day, then more is better.
I'm gonna go dip my Hydrometer now, and see how my group 31 is fairing under my recharge regimen.
