How do you deal with snow on the pop-up?
whwv
I just bought a used 2016 FWC Eagle and have been using it to access all the powder we've been getting CA. I love the camper but am struggling a bit dealing with the snow. Popping the top isn't that much of a problem because I can remove most of the snow with a brush by moving around on the rear-wall steps and running boards. However, dropping the top is much more, uh... exciting....
The other day was the worst as I had about 6" of dense consolidated snow on the roof after skiing. I knew it would be heavy so I though I'd just pull forward a bit and hit the brakes to knock the snow off the roof. Snow didn't budge. So, I then decided to up the effort and do some hotlaps around parking lot driving like an ************ erratically swerving and braking. Didn't work. However, it did work quite well in pissing off the wife....
Since the snow isn't coming off, I didn't see any other options than just dealing with it. Holy crap was that thing heavy. I'd call the Battle of the Roof a tie. I didn't drop it, but I didn't leave unscathed; I write this now with a sore neck reminding me that I don't want to do that again.
So, how do other people deal with the snow? It's a 2016 so it came with the exterior struts. I searched forums and found that some people use speaker lifts to help raise and lower the top, but I think the snow is too heavy for that. The stand people are using seems to be rated at around 100lbs. My roof is setup with a solar panel, yakima rack, and cargo box. With 6" of consolidated snow, my calculations (image below) are coming in at about 550 lbs. I could drop almost 50 lbs by switching the cargo box for a ski rack, but it's the snow that's the problem. Perhaps I lower the front during the day so the snow can try to slide down? Any other ideas?
Clutch
<---Pass
...and how do you do that when the roof is raised? go go gadget arms?
Yeah, doesn't everyone have go go gadget arms!? :p
Ladder.
Otherwise you'll end up breaking something with a heavy snow load on the roof when you try to lower/raise it.
Telescoping versions pack down fairly small.
Martyn
We use one of the Snowhoes made it Tahoe so it's used to deep heavy accumulations. Have had it for 8 or 10 years one of the best winter tools I ever bought.
Nomads365
A Most Adventurous Couple
Snow is no match for hydraulics. These will lift the roof, three solar panels, fans, skylight, and snow.
calicamper
Thanks for this, just sent the link to my cousin who's trying to dig his vacation home out in Truckee!
They need more than that in truckee right now. Most folks I know up there are now maxing out the ability of the Bobcat skidder snow thrower. LOL One friend finally cleared his driveway yesterday. No joke the drifts around the driveway are higher than the house.
Clutch
<---Pass
Babbert
