How many amps?
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
I discovered the dash switch for the air compressor is broken.
The ARB compressor says it has a maximum draw of 20 amps at 12 volts.
How many amps should the replacement switch be rated at?
Right at 20 or higher?
:sombrero:
Ed, at 20 amps, I would think the switch would control a relay that could then handle that. Does ARB run the full line through the switch? If so, then yes I'd do 20-25 switch, but I think it may make a lot more sense to have a low draw switch trigger a 30 amp relay.
The wiring harness ARB included with my stuff uses a relay for the compressor and the solenoids are switched directly.
Yea, what Scott said. Most automotive size relays I have used only draw a miniscule amount on the control side.
See? That's why I have you guys out there...to keep me from screwing up too bad...
I tracked down the wiring from the compressor.
Sure enough it leads to a relay. The markings on the relay indicate 12 v., 40 amps.
Does that make sense?
The switch is a very flimsy paddle switch, SPST, with a small light wired inside. No way the wiring to this rice-grain sized light would handle 20 amps...
What do you think?
:sombrero:
You can get some nice Hella-brand LED-lighted switches from rallylights.com. They carry tons of Hella stuff.
Does that make sense? The switch is a very flimsy paddle switch, SPST, with a small light wired inside. No way the wiring to this rice-grain sized light would handle 20 amps...
It actually might be able to handle 20 amps fine, but it ain't good practice, and is a lot of draw and extra big wiring to muster. Is the switch itself gone? If not, just change the relay.
If so, may I suggest instead getting an FJ40 emergency flasher switch (paint the front different if you want)? You can wire it up the same way and have a more classy stock Toyota switch to turn on your compressor.
Before you use any LED lighted swithces on a rely, make sure there is a protection diode over the coil. If this diode is not there the first time you switch off the rely the back EMF will kill the LED in the switch.
Rob
The switch must have been knocked loose. It was non-functional on the dash. When I checked behind the dash, the case was open and the "guts" had fallen out. Like I said...pretty flimsy.
So, I'll run by Auto Zone or some such and get a beefier STST toggle to fit the hole. The flasher switch idea is good...I'll consider that too...
:sombrero:
5mouse
