How to disable daytime running lights_
Billinsd
Hi, my 2002 Toyota Tacoma 4x4, 4 door truck has daytime running lights and I would love to disable them. Does anyone know how to do this
Thanks
Bill
edgear
aventurero, Overland Certified OC0012
The quick & easy way is to pull the e-brake out one click, then put the vehicle into drive. Seems to work just fine. It shouldn't hurt the e-brake, but it just tricks the truck into thinking that it's engaged - thus not turning on the daytime running lights.
There is another method involving messing around with some wires, but I don't know how to do that...
edgear
erod said:
good fix, but what about the e brake light????
Do you mean the light on the dashboard? I guess it might burn out over time if you do it all the time.
Bighead said:
The attached link has the TSB and additional pics on how to disable the DRLs. Disabling the Daytime Running Lights (3rd Gen). Hope this helps.
Good resource. I might have to check that out. I've only used the trick I mentioned above a few times - like when people are spotting for me at night & I don't want to blind them w/ my daytime runners.
Bighead
erod said:
just out of curiousity...why would you want to disable the drl's?
Personally I still have mine activated but before I retired from the AF I used to get some grief from my base's gate guards for having lights on as I approached for access. There must have been some feedback to Toyota from a lot of people to get a TSB published.
ntsqd
Heretic Car Camper
MicroSquish has conditioned me to really detest things that turn themselves on when I didn't ask for it to turn on and when I don't want it turned on.
Goldenbora
