How to Remove an 80 Series Rear Side Window
LandCruiserPhil
Sounds and looks intimidating, but its easy.
Seeing is believing
[video=youtube;E_0WCuG3YTQ]https://www.youtube.com/watch?t=13&v=E_0WCuG3YTQ[/video]
CO_Hunter
Pretty cool. What about reinstalling though?
I found a few drops of water in the d/s jack compartment. I wonder if I may to do this?
rocrunr
To reinstall use the string method. Take a piece of thin strong string put it inside the grove in the rubber where the body would go. Put the string all the way around crossing it over itself at the bottom. Get someone to hold the window tight in the opening of the body outside. With you inside hold one end of the string with one hand and pull on the other string with your free hand. The string will pull the rubber seal over the lip of the body all the way around the window and your done. Just youtube installing vehicle windows the string method.
Tdavis8695
