S
Scenic WonderRunner
Guest
How to Upgrade your 1st Gen. Toyota 4Runner Brakes....
Grim Reaper offered up some great ideas on upgrading our 1st Generation Toyota 4Runner Brakes over here.
Post up your thoughts, methods, pics and good links to parts.
Can we also upgrade the rear brakes?
Another REAL important upgrade if you are still running the IFS is replace the rotors and calipers with the set from a 93 v6 with the 31 inch tire option. totally bolt on. Then throw a 1 inch master on it. With that combo I can lock the front 33's on dry pavement. I am still running the stock 86 booster and it has a stiff peddle. A 93 V6 booster is a bolt on as well.
I went through hell finding a reservoir 2 years ago and after it was all said and done this was looking like a really good deal.
http://www.marlincrawler.com/brake/master-cylinder/big-bore-brake-master-cylinder.
Unbolt the proportion valve arm off the back axle and zip tie it all the way up.
Here is some comparison pictures of what stock 86 parts look like compared to stock V6 31 inch tire parts.
