Hub size for wheel with timbren axle and hubs
Skinhyfish
Having a custom trailer built.. curious what hub pattern you all have chosen to fit an aftermarket rim and bigger tire. Doing the timbren axle less axles but curious what hub you choose to best fit Offroad wheel tire combo.
thanks
Zach
GlennA
I would recommend the same as your primary tow vehicle. If you change vehicles down the road, you can always change hubs and wheels to match.
billiebob
this ^^^^ make it match the tow vehicle, make sure the axle will work with the same back space too including frame clearance.
nice to just carry one spare for everything OR..... in a worst case...... have 3 spares for the tow vehicle.
john61ct
eTrailer give great support on those
direct line to the Timbren engineers if needed.
I **highly** recommend buying your suspension and wheels, even tires
for optimal "live IRL" visualising and measuring **before** finalising the chassis design specs
FiscAnd
