I want to build a truck slide in camper dolly so I can move my camper in and out of my garage.. It would be on a cement drive way. Since my camper is lite, (1630 Lbs) I’m thinking of using 5 inch caster wheels Amazon5Inch Caster Wheels (Set of 4), Heavy Duty Casters with Brake 2400 Lbs,Locking Casters Wheels for Furniture, Castor Wheels for Cart, And making the frame out of 2 x 6 x 8 ft Lumber in a latter type configuration. It would only sit about a little over a foot off of the floor. Is this doable and is the caster wheels I’m looking at on Amazon good enough for the weight of the camper.
Although I didn’t get those exact wheels, I built my camper dolly to those exact specs you describe. Handled my camper perfectly. I moved mine in and out of my garage with my ATV. Worked flawlessly .
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
