Inexpensive DIY lock in/out mechanism for drawer slides (on a fridge slide)
theksmith
Accuride, Fulterer, and Hettich all make nice lock in/out drawer slides - i've used Accuride before, but depending on the length they all run $120+ easily. i decided to go for an inexpensive but highly usable DIY mechanism on my recent fridge slide:
get the spring indexing pin here ($5-$25 depending on size/style/steel type): http://amzn.to/2ctWD1M - be sure to read the dimensions because many of them use the exact same picture (so one with a 1/8" thick pin looks just like one with a 3/8" on Amazon).
i saw that a guy on here even made his own slides using just ball bearings and bolts: http://www.expeditionportal.com/forum/threads/159292-DIY-fridge-slide. that looks nicely done but i was imagining it could take a lot of tinkering to get everything adjusted to not rattle any and open/close smoothly, so i just went ahead and bought the actual slides for mine. i used these Centerline 758 series in the 28" length: http://amzn.to/2bYcbxz - purchased at the local Rockler store. i think $55/pair for 220 lb rated slides is a good deal - anything above the typical 100 lb rating seems to increase the price quite a bit.
the fridge shown in the video is a Dometic CFX-65DZUS: http://amzn.to/2cQGT9x
vZEMXwHBCRcq54ohun2wMx-gS5xRUIGZVMdJrCV1TRD4fccghA6Zks6lvmoVfRSHyCZ5Ek1z3  cBLCiVlOaFuQ90hOUdXjfbsp0Kjzp-031zFd4h8CFhr47K0oGgE7YWQbGDkAS3V-nyVWlMVo-83JWe_TpBQC9fc8db-gBDOEpPNUMFjJt3NOdjlXA_7GAFDAlDE6fW6_7q3QIaPOO0VI7  _TpIH-NgDsMZ1qFtJOlt46bfi-E45rXZVLjCNbHhpKX-xIexau7qUd_ha7xrL5fZ1ZKD1C4QeGyKeMV7jWAjhAJekDKfSJ  itAE0dhuuiGoDrEiyvaUKt6m8xwLjoyhrGvZc1uTRzKwuDx2B7  lNmlswPrsznknSP1V7JlFc-kREaZkgkeUthTZinARtn01XfdC9a4CjBev9Hk9WZwzFa6x6fZF  9ByjLVnysm1j_4uqafmUuwkxcp0xQhZRnt3hmxcc0AWDkrK3OK  u9fyHuOrGQcF0uuOGqSlyzPMKCPfjdRsIoJcCQNObjgNUwSHyt  B3cZTbA9ysXRynbtASbmyHAEhyaq-wH60cifuWyO8dGKTfg-GXjIQjg9B-tLDsh-dW4FegCYPCY6DwR6GSKujJ4VyvD9J=s800-no
m90JDKHDOH54yF_D_j7rnbBxsdyhNCI59UKTV8eomQnkL7laiv  QdM-WJ6aQ55Lrdp8dnXr9OUcAFGU78JVCkQ1uAFGDjDsx58DU7ZVDg  HqFIx4TPFIU5X284jxABBfz9Z6BhHnV2ANL1OdZWaTXu69JIhu  _YTFs3exuotGMA7XR95-sruz1qWJjNwe6bEyak7JfoG3t3XdI0guY2XJ1rB4VStuOjAa97  k_bC6-8PglqQOYVwvuWazsv-xlY46XyDT_PfkmtKEpBqFaO2gKFTtZvHo6IDXWWfSHls6zH0UU  hgiQRoCc1SDZ36kHokcX-n5tbNVVpfSwS52wcpfHkEtGfrB7zkIw4g713R1gD2MfwxprDHi  Zc25yLdiKYuqMAGCo41YnOQs3jKZLrje2r7BT9WRiTuN8_aLmY  CVHwQHMad5tok3nXIumq3xbraQA2G3Lm1o0gaSMU0AXF5lCNIh  m1oYIDN-YwQsXCWET-jNxdpqmiQAoUn4rPIDy0zYF1-i4_JazQ7elPqddZkXNaJufHPtdmhqUd14tdXMrWCEhWg6bIJWH  vFFeFY8HMxB2Hcavwclbno-v9NYU4InRgyPHMItNT3tfHZV2okkNBOOYgOFTEQ=s800-no
RPhil
Very slick, thanks for sharing.
Also:
Nicely done!
FYI, ORR and ORR make the cheapest heavy-duty slides I've found. I just installed their 48" (non-locking) slide in my own project - it's very nice.
Thanks for this link. Construction looks quite similar to Accuride for a more reasonable price. I will be using the 30" extensions on my build.
banshee01
