Until I figure out a rear folding bench, I picked up a OEM 2nd row bench for my e150. I can't find any pre drilled holes so I'm curious if anyone can help me find the holes. FWIW 2004 E150
Some have bungs some do not. No real rhyme or reason to it. If yours does not have the bungs installed look under the body and you will see a c notch in the cross member flange where it is tack welded to the body those c notches are the factory bolt locations for the seats. If you find these you can then measure from there or drill from the bottom up if you can get at it.
Hope that helps.
Derek
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
