Instrument panel issue Montero 2nd gen 1995
Figuerosky
Quick question I replaced all the lightbulbs for the panel of my Montero 1995 2 gen...for some reason the lightbulbs indicating if it is on 4x4 mode are not turning on...lightbulbs are changed, fuses arecworking...also it is not marking the gas levels...any ideaxircsuggestion to correct this problem? Thanks!
JamesW
Start simple first and give all the contacts on the back of the cluster a good clean. Also give the contacts where the plugs go in a bit of a wipe with some switch cleaner to make sure theres no muck on them either
off-roader
A plain old pink or green pencil eraser is great for removing any oxidation from those contacts. Can also use rubbing alcohol safely.
I'd avoid using a more abrasive eraser or other non-electrical cleaners if you're unsure.
HTH.
Mikenm
