Insulated Refrigerated Body Conversion?
WKCwith5
Hay folks, has any one tried to convert a insulated truck body in to a camper. I have found one that will fit on a F550 or a littel bigger International crew cab. Any thought on this would be appreciated.
Are you sure the weight is in an acceptable range? Most regular dry van bodies weigh more than a camper box really needs to and a 'reafer body is going to be just that much worse. Any pics or explanation as to why you think the insulated box is a better deal? Depending on the specs, not sure I'd use one even if it was free.
Looked into it and got an e-mail back from Vanshield, which like every manufacturer out there do not talk price in any form of communication.
Too bad, as if I was in business I would give a suggested price to give the buyers an idea of what it would cost.
It can be done, I was looking at it, Just need to figure out where the support frames are inside the walls to locate the windows and vents.
Deputy Dan
