s.e.charles
I am aware builders use levels to layout their interior appurtenances. but unless the vehicle chassis is set fixed level (with or without suspension compensation) what purpose does level & plumb serve? as soon as the vehicle is moved from its construction spot, things go awry quickly. under construction, what happens to level when the builder moves about jockeying materials & tools to get the next component templated, measured, or installed?
in the boatyard we used a declivity level to set work right, but the hull was always blocked to hold a constant before any further work was undertaken.
maybe it's me that's a half-bubble off plumb, but I just don't get it.
