Interior LED lights
flyingwil
I currently keep the interior lights off and only manually turn them on if I really need them. To reduce electrical load and increase the life of the bulb, I am thinking of converting to LED interior lights. I have seen Kevin's set up, and it is a sweet set up, and very bright. Brightness can be both a pro and con.
What do you all think?
pwc
Get soemthing with a dual switch, like some of the headlamps you see. I agree, something more mundane for while you're dirving and the passenger might need to check a map, and something hella bright when you can't find your wallet that fell somewhere.
S
Scenic WonderRunner
Guest
I'm Lovin' LED Lights!
I love the very low wattage used for light output produced.
Not only for the interior........I'm constantly looking for an LED underbody/rock light solution!........and other.
I understand your concern as for an extremely bright light in your eyes....and then you head outside of your truck and fall off a cliff. Not a good thing!
There has to be a compromise. We are only limited by our own imagination!
Here is one of the Links I have saved......
....here's to the new wave of LEDS!.....it's the Wave of the FUTURE!..........:beer: .........:friday:
(i've also seen Kevin's LED lights....and love them!)
njtaco
Sort of not what you are asking, but I picked up two of these:
http://www.sylvania.com/AboutUs/Pressxpress/Tradeshowevents/SYLVANIA300/dotit.htm
$8 eash at Autozone.
One is inside my truck cap, over my ammo can. (For tools, not ammo...):)
The other is on the underside of the passenger side visor, as a map light. I can read by the light when my wife is driving, and no glare to the driver. Uses 3 AAA batteries, so leaving it on is not a big deal. I installed them with industial velcro, so they double as a flashlight, if the other 4 stop working. :D
1reddog48
