International 4300 Crew Box DT466 Eaton Transmission Motor home toter RV Camper
bytortruck
This is a extremely nice low mileage 2002 International 4300 with a DT466 and a Eaton Transmission. It only has 107,500 miles on it which is real low considering these trucks were built to run 100k miles a year. Full size spare under the truck. The truck has air brakes, air suspension, air seats. It currently has a crew body on it that was over $130,000 new and some specs are below.
The truck is rated at 25,999 GVW so no CDL is required.
This would make for a great Camper, overland, Moterhome, Toterhome, or Hauler Conversion. Also the box can be cut in half right above the tool boxes then you have a service truck. It is priced very well just as a cab with no box on it.
- Galvanneal 2" Thick Insulated Body
- 8 Person Crew Seating + 2 Person Cab = 10 Person Total
- Crew Compartment (Access from Rear of Body)
- HVAC System (Cooling 33,000 BTU, Heating 46,000 BTU)
- 8 Usable Exterior Compartments (15" Deep with Adjustable Shelving)
- Crew Compartment Overhead & Lower Shelving for Crew Gear
- Heavy Duty Vinyl Upholstery and Retractable Seatbelts
- 2 Emergency Exit Windows
- R14 Insulation in Ceiling and Side Walls
- Warning Light Package
- 3 Exterior Scene Lights
- Master Disconnection Switch
- Double Panel Compartment Doors
- Stainless Steel D-Ring Handles (Lockable)
- Structural Channel Subframe
- Shear Plate & Spring Body Mounting
- Compartment Lighting
- Painted Steel Interior Side Walls
- Floor coated with a rubberized coating.
- Spare Tire Storage Underdeck
- Body Painted to Match Cab
- 100 Gallon Fuel Capacity
- 4 Batteries
Call or text Brandon 206-225-6611 or email Brandonblarson@gmail.com
Here is a link to some HQ pictures http://s29.photobucket.com/user/turbo94gto/slideshow/03 International 4300 Crew
dlh62c
Lots of possibilities there.
Getting insurance on a commercially rated vehicle can be problematic. After the conversion it's less of an issue.
