pwc
I've tried searching but I can't seem to find what I'm looking for.
I'm trying to figure out a good filtering system to put in a Defender 110 with the rear seats removed. my requirements are:
I'm thinking right now of something like an undersink unit for houses but need to make sure it'll take care of the right bacteria. Ideally, if I have the space, I dream of just using something like the GE reverse osmosis and the 2 gallon tank. My reason for that is so I can run the water pump from my internal storage, filter it and store it in the 2 gallon "clean" tank. Then put a check valve in the right place and I'll always have 2 gallons fresh and ready when on the trail.
I've already decided my storage in the truck will likely be 6 2.5 gallon Scepter cans. They fit perfectly on the floor behind the front seats, can be lashed down easily and I like the concept of distributing the load in case one springs a leak....I only lose 2.5 gallons. These will always be filled with non-north-of-the-border-potable water and keeping them small means ease of transport to the water source if need be. With these always being non-potable, I never have to worry about getting things mixed up and I like simplicty.
- cleans any crud that might give me the crud when south of the border
- works with pressurized water input (no hand pumping)
- easy to maintain
- mountable
- dispenses from a tap
