Inverter Cable
Maximus Ram
OK, I searched ...nothing
Simple question...I picked up a xantrex digital xpower 400 inverter today for 10 bucks. It has no cables with it, but I teseted it with some speaker wire and it powered my notebook computer just fine. Soooooo, I am thinking that I want to mount this in the cab of the truck so I can take the laptop with me.
What would be the least expensive method to get the max amount of power out of this little inverter.
I see most inverters use 4g cable with lugs on them. Is this the minimum gauge I should use or can I get away with less ?
I want to run it directly off of the battery too.
Thanks,
Matt
Maximus Ram
Alright..then I'll look at 8 - 10 gauge and make me a couple and get this thing hooked up.
Thanks for the quick response, guys....:friday:
Maximus Ram
What about using a set of 8 gauge jumper cables ?
Harbor Freight has a 12' set for under 10 bucks and I have a 20% coupon to boot.....
pods8
Have you looked into if you can just get an affordable DC-DC plug for your laptop rather than converting your vehicle DC to AC to convert back to DC?
Maximus Ram
Now what fun would that be:D...thats to easy:coffeedrink:
Plus, for some reason I hadn't thought about that solution.:sombrero:
Guess I'll check e-bay for an adapter or maybe google it
Thanks:wavey:
