Snarky
Hell Paso
I'm interested in discovering whether anyone here has worked on extending the fuel capacity of Inverter type generators.
Specifically, I'm interested in extending the capacity of the Yamaha EF2000IS. Though I am also interested in the EU2000 or any other comparable generators.
I'm wondering if it's possible to use a standard metal jerry can as a fuel source.
Hopefully, with as little modification as possible, I'm envisioning a jerry can modified cap with a hard pickup tube that goes to the bottom, connected via hose to spare generator cap. With the idea being that you can swap fuel cans as they get depleted. I'm hoping to see if someone has done more than just poured the fuel into the top of the gen.
I've seen some fuel setups such as this:
This seem to utilize a marine type fuel cell as the fuel source and then some connectors. I'm wondering if these systems rely on carb vacuum or gravity siphoning or what?
I'm hoping to use one of these generators long term to power a small self contain A/C unit for desert days and gulf coastal use.
At then some high powered lighting at night for evening surf fishing.
I'm also interested in any LNG or propane conversions done on these types of generators, if anyone has something they would like to show off.
